Guest viewing limit reached
LHensh
I have bought a TP Link Home Plug kit to try and get internet in my garage.
The kit works fine in the house but unfortunately I get no connection in the garage.
The garage is on its own circuit, however from what I have read online this shouldn't cause any issues.
Could it be the fuse box in the garage (see photo attached) that is causing the issue? If so how easily can these be replaced/upgraded?
Is there anything else that could be causing me to not get any connection in the garage?
Update: have just tested the powerline on a socket upstairs which is on a different circuit to where I had it working downstairs and that works fine.
So I guess it's a case of understanding how the garage is configured differently to the main house?
If you can simply run some network cable to the garage you will have a much faster and more reliable solution. You can get outdoor UV rated network cable for doing this, for example:
If you need several outlets in the garage then you can use a small switch. If you also want wifi then a router but to do it properly you don't want to have it doing NAT, you want only to use the LAN side and have no DHCP, etc, so it looks just like the LAN side of your main router and all DHCP requests are done via that.
And in English?
Most wifi routers assume they are the only device, and will try and assign IP addresses (unique numbers) to it's clients, and it's better if the unit in the house does all of that. So it needs setting up by someone with a bit of tcp/ip networking knowledge.
And in English?
A "router" is quite complicated because it is doing several things. The switch aspect (e.g. 4 ports you can plug stuff in to) is the simplest part, but it also has (usually) these:
  • Network Address Translation (NAT) so the single internet protocol (IP) address that your internal provider (BT, Virgin, TalkTalk, etc) allocates to you can in turn be used by many devices in your home. Originally used to get round the limited availability of addresses, but turned out to be a handy layer of security as the outside machines can't simply reach in to a NAT'd device without added steps being enabled (port forwarding, etc) since the NAT layer only forwards replies to known outgoing requests.
  • Dynamic Host Configuration Protocol (DHCP) so that those devices don't have to know in advance what IP they can use, they just connect and ask for a unique address to be allocated for them.
  • WiFi as the radio bridge from IP packets to some devices radio, along with password or similar control of radio access.
  • Firewall (not always) to limit what traffic can come and go on the various interfaces.
As @timhoward has already said, a router usually assumes it is the master of all connected and you will get in to problems if you try to link more than one together without some understanding of the above. Or you pay someone (company, local guru) to make it all happen for you.
If you use something professional, or something that is open for anyone to fiddle with, then you can make two or more work as if they are one network by having one as "master" that does NAT & DHCP and the others just do the wifi and switching aspect.
If you have nothing better to be doing, then this has info on using a 2nd OpenWRT device as a dumb access point (wifi extending, etc):
And to allow devices to roam more easily from one wiif point to another you can use these steps:
Or pay the likes of Cisco a wad of cash to make it happen for you.
I actually have some of this stuff, but use a 22 year old nerd (son) to set it all up.
Have BT fibre to property into the BT optical receiver type thing, which then feeds a BT wi fi router. The wifi signal from this isn't normally used, but it has two CAT5 cables connected to it, with one going to an outdoor wi fi router, and the other going to an indoor wi fi router. There is also a cheap plug in wi fi Rx/Tx in one property, that receives signals from the outdoor router, and transmits them through a doorway to the back of that property.
I’m not sure, but does powerline not utilise the earth wire rather than a live conductor?
Maybe you have an issue with the earth in there?
All of the network over power adaptors i have used use live conductors, i have had success using TP link ones from a house to a remote building with TT and no earth connection between them a few times
But thats not to say that they all work like that, it would be interesting to know
Would there be any suitable WiFi options I could use given that it's just the ability to stream HD video that I'm looking for?
I had considered mesh system but I'm keen to keep hold of the router I've only recently purchased.
Wireless access points maybe?
I've slept on it and think this might be my best option.
Would there be anything additional that I would need to consider as I would be doing this DIY? For example how easy is it to terminate the cabled properly?
I'd then connect to an AP once in the garage, so will read up on your advice re setting this up correctly.
Is there any key difference between the product below and the one you suggested as this one is slightly cheaper?
Terminating the cables into IDC connectors is quite easy if you have a decent tool, worth spending a few £ for a decent one, not the very cheap & nasty plastic ones. Plus get at least a basic data tester, a transmitter & receiver that cycles through each of the 8 cores, and tells you continuity is OK e.g. with a simple 8-LED display.
LHensh
UK
Internet in Garage - Powerline Issues
LHensh,
Spoon,
