Ip44 230v zone 1?! | on ElectriciansForums
Discuss Ip44 230v zone 1?! in the Lighting Forum area at ElectriciansForums.net
in any zone RCD protection is required. not just zone 1. IP44 is suitable for installation in zones 1 and 2.
Minimum requirements for zones 1 and 2 is IPX4. The presence of additional rcd protection does not affect this rating.
Zones 1 & 2 the equipment must be IPX4 so IP44 is fine unless you are using water jets where IPX5 is required.
agreed, though any circuit within or passing through the zones required RCD protection, irrespective of it's IP rating and suitability for installation within zones. manufacturers need to get a grip and supply instructions that are compliant and not confusing.
I agree but existing installations may not have additional rcd protection however you can still replace a like for like/similar light fitting as you are not altering the circuit.
The zones are from the finished floor level what if you shower try is not on the finished floor level what if its raised up 6inches would you measure the zone from the tray or the bathroom floor
showers spray the water jets donwards. something to do with gravity.they ain't spraying up to the light unless it's a cat having a shower, then all bets are off. them pesky felines pi$$ anywhere.
The height of zone 1 and zone 2 are limited either by the horizontal plane corresponding to the highest fixed shower head or water outlet, or the horizontal plane lying 2.25 m above the finished floor level, whichever is higher.
So it is the finished floor level you go off.
floor. that's what it sez in the magic picture book, commonly called on site guide.
last time i experienced a horizontal plane,I was landing it. makes a right mess if you hit the runway at 45 degrees.
Reply to Ip44 230v zone 1?! in the Lighting Forum area at ElectriciansForums.net
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
Thank you..... & did have all the fan isolator/ fuse in same plate (click) so quinetic wouldn't worked on this occasion
