View the thread, titled "IR readings Puzzeled" which is posted in UK Electrical Forum on Electricians Forums.
hi there
carried out IR test on radial lighting circuit today. L-N 700MOhms N-E 650Mohms L-E 320Mohms just wondered why the L-E would be nearly half the value ???? ( test carried out at 500v dc, TNCS system circuit disconnected at board)
If you are looking for reasons why they vary so much
Then check how good the batteries are in the meter, if they are ok then check the test leads had quite a few which failed at the plug through the continuous flexing they get
maybe thayt's why my joints are failing... all this flexing.... not just bending to pull cables, but lifting beer as well.
Reply to the thread, titled "IR readings Puzzeled" which is posted in UK Electrical Forum on Electricians Forums.
