IR test method 2 | on ElectriciansForums
Discuss IR test method 2 in the Australia area at ElectriciansForums.net
J
james king
is this test exepatble and does it bypass tranny and bulbs ect? i have been told on here befor ye so i am just wondering
it is acceptable when by performing method 1, you might damage equipment which you are unable to disconnect. e.g on a PIR/ for a new install, on initial verification, you would always use method 1, as in that case there would be no loads connected at the time of testing.
sorry i dont understand that? i thought method 2 was used when it was nearly inpossible to dissconnect some equiptment eg bulbs and trannys also neaons??? can u leave them in and use method to to bypass the equiptment?
suppose you had a load of high bay lights 25 ft. up in the air. would the client pay for the hire of a cherry picker and the time to remove the loads for you to test?
yes it does. because you are shorting out L/N and testing from there to E. therefore, you are not applying the test voltage across the load.
definitely. some appliances e.g. computers have high earth leakage currents, but only around 3-4mA, so would still give you a reading L/E of around 80kohms at250v.
as near as you can get. Remember to check your leads are OK before doing the test as you could think you are performing the test when actually you are just getting eroneous (spelling) readings.
0.00 Mohms doesn't always equate to a dead short reading. If you have any surge protectors connected to the circuit(s) under test, they will give you that reading when using the method you refer to. You must therefore disconnect them, or if that isn't possible, reduce the testing voltage to 250V, making sure you have noted this on your report.
Reply to IR test method 2 in the Australia area at ElectriciansForums.net
https://professional-electrician.com/technical/replacing-a-consumer-unit-in-a-dwelling-niceic/ All circuits should be tested
I don't think it will work with only one stake unless some meters have different operating parameters. It doesn't necessarily have to be a stake...
