Is 2way switching for a fan the same wiring as 2 way lighting?? | on ElectriciansForums
Discuss Is 2way switching for a fan the same wiring as 2 way lighting?? in the UK Electrical Forum area at ElectriciansForums.net
J
J_c9sh
hi, doing some work for client and they have asked for a fan to be 2 way switched, 1 switch in utility room and the other in the bathroom next door
my query - is 2 way switching for a fan the same wiring as 2 way lighting with a permanent feed going to the fan for a run on timer??
thanks
I'd go for 2 separate fans as well - one in the bathroom, one in the utility room. Then you could have the fans coming on with the lights, like 'normal'.
Otherwise the lights would all come on together unless you start messing about with diodes and relays and that, by which time you might as well have installed 2 fans anyway.
this is what they want
utility room - 1 2g switch, one for light and one for fan
bathroom - 1 2g switch, one for light and one for fan but 2 wayed with utility room switch
lights on seperate switch
just need to know correct wiring
i never installed 2 way fan control before,i have always installed 2 seperate fans as you mentioned trev but if in future i was to do it is wiring same as lighting - im going to talk to client about changing to 2 seperate fans, makes more sense
Light = item of electrical equipment.
Fan = item of electrical equipment.
Both require N and switched L and one requires and permanent L.
No reason why you can't 2 way switch, EXCEPT,
Upon loss of switched Live, you can see one has gone off, but the other one goes into timed off mode.
Unless you fit an indicator at each switch, you'll never be sure the fan is going to go off.
Reply to Is 2way switching for a fan the same wiring as 2 way lighting?? in the UK Electrical Forum area at ElectriciansForums.net
The 2 inputs are separate and there should be no interlinking between SL1 and2 If there is there has to be a wiring error or a fault with the...
Thanks again for your help, now solved đź‘Ť
