Is 2way switching for a fan the same wiring as 2 way lighting?? | Page 2 | on ElectriciansForums
Discuss Is 2way switching for a fan the same wiring as 2 way lighting?? in the UK Electrical Forum area at ElectriciansForums.net
J
J_c9sh
hi, doing some work for client and they have asked for a fan to be 2 way switched, 1 switch in utility room and the other in the bathroom next door
my query - is 2 way switching for a fan the same wiring as 2 way lighting with a permanent feed going to the fan for a run on timer??
thanks
if you're not using the lighting switching to activate the fan, then it's a simple 2 way switching arrangement to activate the fan. a permanent L to the fan if you want overrun. isolator is optional if there's natural light available for maintenance purposes.
Firstly i would check the required ventilation rates for these two rooms as they will be different if you check the book, also they are ducted together so I guess this must be an in-line fan so someone can invertently turn it off if required in the other room.
All sounds alot of agro with no real gain. The same amount of wiring and the same amount of ducting. Only thing being saved is the cost of a fan unit. If I came across this setup I would assume DIY.
only way i can see it working as you want it to is to drop a perm feed to fan and bring 2x switch cables off from the isolator to the switches...!
that way you would need to turn the switches off after use in that room.
Why does the client want the fans switched independently from the lights? The whole point of switching it all together is so you can't forget to turn the fan on.
Sure the client knows, but will the next person who moves in know, or guests, or will his wife/kids bother every time?
Either they'll have to put up a sign or tell every visitor (which I can't see happening) or a visitor goes to use the bathroom, goes to the switches - "OK this one does... Nothing, this one.... Ah, turns the lights on." Visitor uses the bathroom, turns the light off when leaving, next person goes in, bathroom smells of farts. Embarrassing for all involved.
In short, if you have a weird switching arrangement the fans won't get used, making there no point in installing them at all.
but humidstats won't react to farts, unless they are extremely wet ones, in which case, who cares about the fan? more a case of rinsing underpants.
Lol my stomachs hurting from laughter,cheaper setup is what we have in our house 1 x lazy sparks who has never got round to fitting the extractor that has been collecting cobwebs for the last 5 years,ill do it one day but for now the oust spray works a treat,must get that fitted.
Moving slightly away from the electrical side...
If you have two fans sharing one duct then you will also have to fit one-way (back-draft) flaps in each fan branch. If you don't then air from one room will get pumped into the other, and vice versa. Not great if you have post curry fog seeping into the utility room:sick:
Reply to Is 2way switching for a fan the same wiring as 2 way lighting?? in the UK Electrical Forum area at ElectriciansForums.net
The 2 inputs are separate and there should be no interlinking between SL1 and2 If there is there has to be a wiring error or a fault with the...
Thanks again for your help, now solved đź‘Ť
