Is 2way switching for a fan the same wiring as 2 way lighting?? | Page 3 | on ElectriciansForums
Discuss Is 2way switching for a fan the same wiring as 2 way lighting?? in the UK Electrical Forum area at ElectriciansForums.net
J
J_c9sh
hi, doing some work for client and they have asked for a fan to be 2 way switched, 1 switch in utility room and the other in the bathroom next door
my query - is 2 way switching for a fan the same wiring as 2 way lighting with a permanent feed going to the fan for a run on timer??
thanks
Fantastic diagram rich, thanks but does that mean from diagram that no strappers are required, just a switch wire from each switch, both connected to the fan?
Sort of. This will mean that in each location you'll end up with just one light swtich in each room and the fan operated if either light is on. The double pole swtiching then prevents feedback turning the other light on. Whether this will suit your situation, I don't know?
Rich
Reply to Is 2way switching for a fan the same wiring as 2 way lighting?? in the UK Electrical Forum area at ElectriciansForums.net
The 2 inputs are separate and there should be no interlinking between SL1 and2 If there is there has to be a wiring error or a fault with the...
Thanks again for your help, now solved đź‘Ť
