Guest viewing is limited
Ay up Each..!
This bloke I know paud £500 for a new CU but with no certifcation. His electrician said it would cost him more for certification and bonding....
These are the types of "electricians" that give good honest hard working ones a bad name. £500 pounds for a CU with no certificate indeed.
I'm doing mine for £320 bonding and cert included. Lost a job last week - too expensive. So counter offered £300 all in. I got the job. £20 quid what a stinge!
If bonding is included then £300 is dirt cheap!
Some old terrace houses have the stop tap right at the back of the house in the kitchen with the CU right at the front door... Some times takes most the day up just bonding... There's your profit gone
on my website I have a disclaimer that says install must be evaluated before special offer can be given. In other words if I see its going to be a ball-ache of a job I tell them it will be more. In this case water and gas was all of 4m from board under floorboards. Just over half a day, job done!
With customers prepared to attempt most smaller electrical jobs themselves, the one job left that most still wont tackle is a cu change, therefore if you cant charge a good price for this what can you? I never lower my prices to undercut others for 2 main reasons....firstly many customers will fabricate a low previous quote out of thin air and see if your naive enough to work for less, and secondly I would have loads of work but not a lot of cash to show for my efforts, also not quite sure what the JIB rate has to do with what anyone is prepared to charge their labour out at?
In reply to why I raised the jib rate-I was merely bringing up the fact that for £16 an hour ALOT of sparks are happy with that. The money ontop of that is usually to cover your business expenses. £20 per hour to me gives me a decent living and covers my running costs. I charge this on domestic work as this is how I get the work. In rare cases I will charge more. But £160 a day for my personal wage is enough it's £800 per week before tax etc. I am not greedy and I think some people ask to much from their customer. As I said previously it also depends where you are £600 a week in london take home wouldn't supply anywhere near as it does up here.
*Edit to say - If I am fault finding I charge more as this is a skill that alot of sparks don't have. No disrespect but theres installers and testers and there is a big difference. I charge a price which is dependent on the nature of the fault. I have no prices set in stone but I do log prices that I have previously charged to give me a rough idea of where I'm at. Ther other day I went to a fault on a kitchen socket. It wasn't working did IR test then continuity and found the break. Replaced cable. I was there an hour and a half. I charged £60 I thought it was very reasonable. I had an off cut of 2.5mm in the car so that cost zilch so £60 covered petrol and my wage. Not bad for 1 & half hours.
OK guys
How much would you charge for a cu board change that has 4rcds and 48mcbs including bonding?
That is obout the norm here in France for a 4 bed house.
I look forward to hearing your comments
OK guys
Your looking about a grand maybe more
OK guys
My understanding of French regulations is that all circuits are radials, so 48 radials to locate the ends of and test - that's a lot so certainly about 2 days plus all the parts etc so you're probably looking at £750 - £800 (don't know about notification and/or associated costs)
!...Is £495 to little to charge to supply & fit a consumer unit..?!
Business Related
se7aq,
rocker,
