Is a fused double pole isolator classed as a consumer unit. | on ElectriciansForums
Discuss Is a fused double pole isolator classed as a consumer unit. in the UK Electrical Forum area at ElectriciansForums.net
Uk
I’ve just replaced a faulty 63A double pole isolator supplying a feed to a consumer unit several meters away to a flat.
ive come to do the notification on the niceic web page and there is no appropriate category to tick other than
circuit addition or alteration in a special locatiom
install a replacement consumer unit
partial rewire
rewire of all circiuits
install one or more new circuits
new build
unless I call the isolator a consumer unit ( which it isn’t) I don’t have a category.
thanks in advance.
I would have called nic but there shut now And I wanted to get this finished tonight. Any thoughts.
That’s what I was starting to think, but surely that can’t be right.
Sorry, you just said isolator in your op.
I suppose you could argue that as it changes the characteristics of the circuit it should be notified.
If in doubt just notify it a consumer unit change, if wrong your only crime is miss describing the works. But at least you’ve notified it and covered yourself.
I don’t want to notify that I’ve done the consumer unit, as I haven’t. The cu in place at moment was fitted by a non electrician or an electrician that really shouldn’t be. So I don’t want my name associated with it if someone searches building control In the future to see who installed it.
I know the cert I am supplying states the extent, so I think I’ll just notify under consumer unit.
maybe I’m over thinking it.
If like for like then its maintenance and repairs, not notifiable, as there has been no material change to anything significant from initial installation.
MWC for me. Just to record that it has been tested and competently installed.
I think you did right Pete, I've just looked up consumer in definitions (never thought I'd ever have to do that) and it says 'one or more fuses, circuit-breakers etc etc' So it's a consumer unit.
Regarding responsibility, I put the certificate number, in this case a MWC number on the part p notification and the notification ref number on the certificate. The certificate has more detail on the scope of the work covered.
partial rewire
new build
thanks in advance.
Hi, it looks like you are trying to register it as "notifiable work". if you have just replaced a switch fuse don't feel that it comes under notifiable work. If anything I would do a minor works certificate to cover yourself
Nice one. That clarifies things nicely. I was starting to thing I’d made a mistake and a call to nic tomorrow to correct things. But if that’s the definition. Brill.
Reply to Is a fused double pole isolator classed as a consumer unit. in the UK Electrical Forum area at ElectriciansForums.net
For a TN system neutral is deemed at earth potential.
What is the distance from the point outside the house to the shed?
