youmustwhipit
Discuss is it safe to use this plug? in the UK Electrical Forum area at ElectriciansForums.net
thanks for heads upYour going to need to upload the image again
thanks all. I guess I am an idiot
for my education, what aspect of it is dangerous – what is it missing?
It's highly doubtful that you will be able to purchase just a replacement cover for it. The whole thing would need replaced.thanks guys
fyi i found this in a rental and wasnt sure if they had been using it or not. i just moved in.
you will be horrified to know that before posting the pic i plugged it in and then plugged it out (after turning off the swtich)
if i want to replace it is that an easy job to get a new top or is it more the case that i need a whole new plug and cable
What do you think is missing, clue exposed front?thanks all. I guess I am an idiot
Are you serious, is this for real? I'm sure you have other 13A plugs that are complete so it must be pretty obvious what is missing, leaving live terminals exposed!for my education, what aspect of it is dangerous – what is it missing?
It's just a simple case of fitting a new plug to the existing flex.thanks guys
Reply to is it safe to use this plug? in the UK Electrical Forum area at ElectriciansForums.net
