View the thread, titled "Is it within the regs to fit sockets without securing them to a wall/cupboard?" which is posted in Electrical Wiring, Theories and Regulations on Electricians Forums.
On domestic new builds that I’ve done in the past, I’ve overcome this problem by having a switch / SFU above counter but then run a long length of chased in flex from it downwards to below the plaster line, couple of meters of slack and then fitted a 13a trailing socket.
The only time I've ever done anything like this is when I provided a supply under some units, fed from a bank of light switches, to feed some LEDs
to be fitted in the plinth.
When the LEDs turned up, their PSU was a wall wart, so I fitted a surface box and a 1G unswitched socket to a small rectangle of left over plinth, with a couple of cable event cable clips, and pushed the whole lot under the unit s.
If it like mine, there will be a bank of grid switches.
recipe for failure. the number of failed grid switches I've had to replace over years is approaching 3 figures. last one was a bank of 4, and 3 of them had been bridged out. they are rated at 20A, so why do they keep failing at 10A ???
Reply to the thread, titled "Is it within the regs to fit sockets without securing them to a wall/cupboard?" which is posted in Electrical Wiring, Theories and Regulations on Electricians Forums.
