Is there a chance Dual RCD Consumers could be "banned " from rentals soon? | Page 5 | on ElectriciansForums
Discuss Is there a chance Dual RCD Consumers could be "banned " from rentals soon? in the UK Electrical Forum area at ElectriciansForums.net
LukeD
Nearly Esteemed
Supporter
Client has purchased a night flat in Edinburgh. Its perfect for using as a ST rental during the festival as the agents claim £6k a week is the value based on rooms and location. It was nicely decorated in 2018 and has a twin RCD Board . Wiring etc etc looks very good .Its a tidy install , sockets etc all good . Worth leaving as it is or will he hit a "wall" in the next few years with new regs about not having RCBO board do you thinK ? IT has a FRESH EICR that showed no issues .But recommended a board swap . He has plans to remodel it in 5-7 years and will be doing a full rewire etc etc then .
You mean switching the line ?
That's all that's needed
If there is little risk of a "hot" neutral then that is true. You get the full isolation for testing and selectivity with any up-stream RCD protection for N-E faults.
However, if you do get a hot N situation then you rely on the RCD action for tripping, and that is far slower than the usual magnetic part of the MCB side of things. Also most SP+N type devices only have the arc-chute in the L side so a high energy N current fault might total the device, etc.
In the UK it generally will do yes. But in another country where supply polarity cannot be guaranteed or where neither pole of the supply may he reliably connected to earth then the difference should be obvious.
I'm not intimately familiar with conventions of electricity supplies in other countries. It's easy to forget that polarity is of less importance in other parts of the world and that reliable earth connections often aren't considered to be of as much importance as perhaps they ought to be.
Reply to Is there a chance Dual RCD Consumers could be "banned " from rentals soon? in the UK Electrical Forum area at ElectriciansForums.net
