Is this ceiling light compliant? | Page 2 | on ElectriciansForums
Discuss Is this ceiling light compliant? in the Lighting Forum area at ElectriciansForums.net
Status
Not open for further replies.
Mains is low voltage.
You know what he means. You are just being pedantic. It is often easier to use the term 'low voltage' in this way to the layman. No point confusing members of the public with technical definitions of LV and ELV.
But if you do that the layman will never learn from his/her mistakes.
Nothing simple about using the wrong terms which could cause confusion and danger.
As far as a DIYer is concerned, 230V AC is high voltage, whatever the official definition is.
Reactions: DPG
Status
Reply to Is this ceiling light compliant? in the Lighting Forum area at ElectriciansForums.net
Why would the RCD fail … yes it can happen but then it may not. Without it you have no protection on the TT System
4K
