is this dangerous | Page 2 | on ElectriciansForums
Discuss is this dangerous in the UK Electrical Forum area at ElectriciansForums.net
steve_has_prob
[ElectriciansForums.net] is this dangerous
Could you clarify if this is dangerous the wire that change from from blue to red seem to be have been extended by twisting together as there no block connector there as there is further on in the circuit this seems to be some sort of extension to wire up the light above the mirror in the holiday flat as its only to a light will be ok?
if there was a leak from the flat above would that make it a hazzard ?
Steve
Its been discussed in early posts.. If its redundant cable and not live apart from looking naff is no concern.. Only a spark that been there can advice if it is really bad..
If your complaining then personally your wasting your time.. from you sending the letter in and them realising whats going on they will have it repaid and it will be brushed under the carpit..
If it was the hilton then fair enough.. However with shelf like that and wallpaper like that.. I suspect this is a bargain basement holiday which with respect cant see it costing too much anyway..
If it was shoved down behind the mirror...im guessing you pulled it out to take the picture? What the hell even possessed you too look behind the mirror whilst on holiday, slightly random - unless you're going around looking for things you can maybe make abit of cash on.
Don't get me wrong, its bad, dangerous and it wants correcting but come on
No was ill in room for about 4 days i counted all the dots on the wall paper out of bordom LOL and saw a shadow of something on top of the light, looked at it and it was the block conectors and as you see it in the pics is how it was if you look closely the wires have been painted to the wall.
You need to dabble in an escort then.. Or at least beer..
LOL
I say it as it is
As i quoted not claiming regards this electrical issue, thought it was dangerous and the quote on here back it up.
As for me posting these as evidance im sure there are easier was of getting a report with those pics and this site isnt available to read without joining.
Dear mr holiday company could you please join this site so you can!!!!!!!!!! i think not
Thanks for the advise and psychoanalyse
Regards
Steve
LOL
I say it as it is
Regards
Steve
No problem .......... we're always happy to help. :)
Reply to is this dangerous in the UK Electrical Forum area at ElectriciansForums.net
Definitely looks like the cpc (earth) has been sleeved and used as a neutral conductor, this is not permitted. You are going to need an...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
