is this dangerous | Page 3 | on ElectriciansForums
Discuss is this dangerous in the UK Electrical Forum area at ElectriciansForums.net
steve_has_prob
[ElectriciansForums.net] is this dangerous
Could you clarify if this is dangerous the wire that change from from blue to red seem to be have been extended by twisting together as there no block connector there as there is further on in the circuit this seems to be some sort of extension to wire up the light above the mirror in the holiday flat as its only to a light will be ok?
if there was a leak from the flat above would that make it a hazzard ?
Steve
LOL
I say it as it is
As i quoted not claiming regards this electrical issue, thought it was dangerous and the quote on here back it up.
As for me posting these as evidance im sure there are easier was of getting a report with those pics and this site isnt available to read without joining.
Dear mr holiday company could you please join this site so you can!!!!!!!!!! i think not
Thanks for the advise and psychoanalyse
Regards
Steve
I think you may mean psychoanalysis.
yes it is very dangerous
we use tape for repairing outer insulation only and only temporary.
and must be properly replaced or bonded with in a weeks time.
a repair like that was not done by an electrician and if it was he should have the crap slapped out of him!
depending on what its running
if a temp repair has to be made then a hardware guard is put in place around it to protect people.
we try to make things as modular as possible for example some machines we have modified to use a modular control and power system. a bit more complicated to build but extremely fast to repair with minimal downtime.
simply replace the defective module and repair the faulty one for reuse later
Reply to is this dangerous in the UK Electrical Forum area at ElectriciansForums.net
Definitely looks like the cpc (earth) has been sleeved and used as a neutral conductor, this is not permitted. You are going to need an...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
