Is this installation what Wago had in mind | Page 2 | on ElectriciansForums
Discuss Is this installation what Wago had in mind in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
Saw this being done today .....
[ElectriciansForums.net] Is this installation what Wago had in mind
OK, its above the ceiling, but the same individual did the same before he dropped a connection on the RFC below the floorboards ...........
Not convinced that the MF rating is achieved by the tape ............. but willing to be persuaded.....
I'm a bit new to wago , have seem them before , and used similar on panels (control wiring )
Obviously tested tried and tested
What's everyone's opinion on them as oppose a screw terminal
Are they fail safe
Anyone had problems with them
Use them ( or their equivalents) all the time now. Only had one problem where the use of a "push in" Wago was causing a high r1 reading on a ring final circuit.
No problems and a lot less stress than junction box screws when you are balanced above wads of insulation, and mouse droppings in a roof space on a hot day with wasps and blue bottles buzzing around.
Customers should always be reminded to remove all corpses from loft spaces,before work commences...;)
I love wagos, the only PITA is when using the push connectors with cpc so I prefer the lever connectors with those.
snipe nosed pliers solve that problem.
Reply to Is this installation what Wago had in mind in the UK Electrical Forum area at ElectriciansForums.net
