Is this the real bible eicr code breaker | Page 2 | on ElectriciansForums
Discuss Is this the real bible eicr code breaker in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
1.3 no distributer earth connection between service cable and MET.
1.4 minimum CSA of meter tails.
1.6 isolator enclosure is not made from non combustible material.
what would you regard as error ? is it the wording you disagree with or the content
Lack of a connection between the supply cable and the MET would be a TT earthing system and would not warrant a code.
There is no minimum CSA for tails in BS7671.
The requirement for non-combustible enclosure only applies to the consumer’s installation, so no code if the isolator is the Distributer’s equipment and at most would warrant a code C3 if the isolator is the Consumer’s.
Thermal damage has nothing to do with the requirement to use non-combustible material for the enclosure.
I’ve got the book.
They have also deemed pvc cables concealed in walls a C2 without additional protection via 30mA rcd, mechanical protection etc.
I’ve got the 17th edition version 1 book also given to us in a tool box talk ,where in that version cables concealed in walls etc ,is given what I would say as the industry collective opinion of a C3.
Don’t know if they have changed their minds or it’s a mistake in the publication?
It’s decent but as the inspector the codes are yours to put down and no one else’s in my opinion.
There’s loads of codes in the book I feel are not what I would code.
Oh dear! Cables not protected by an rcd in a wall a C3 but without mechanical protection a C2? (17th edition version) A bit of a cock up id say[ElectriciansForums.net] Is this the real bible eicr code breaker [ElectriciansForums.net] Is this the real bible eicr code breaker
^^ that's appalling
Lots of Napit members are going to be using this as the gospel truth
How can a cable not protected by an rcd be a C3 yet the likelihood of having mechanical protection is nil, but that is a c2 when both methods are acceptable to use ? they must be the same code if both are missing
Inconsistent - must have be written by the guys who produce the regs...
This is rubbish.
There is no prohibition in BS7671 against running cables outside of prescribed zones or diagonally. They need to be protected by one of the listed methods.
I just hope people don’t start quoting this book as gospel and use it as the be all and end all of eicr coding
Reply to Is this the real bible eicr code breaker in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks for the reply littlespark. Yes the works have been carried out. Surely it is fraudulent because basically the document is Not...
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
