Issueing "danger notices" | Page 2 | on ElectriciansForums
Discuss Issueing "danger notices" in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
So who does these and why?
This has been passed to me for my comments by a customer:
[ElectriciansForums.net] Issueing "danger notices"
The "issue" is lack of end to end continuity of one of the socket circuits - I don't think this is a sensible use of a danger notice.
Do you?
QUOTE - [ I honestly see no purpose at all in issuing these notices ].
what about avoiding legal liability issue's ?
If your concerned about a certain danger
you advise the customer, customer says no
for what ever reason, maybe no money ?
If you issue a notice, then the ball is in there court
should something happen down the track.
sound logical to me
Have I missed some thing ?
The last time I used one of them is when the cut-out was hanging off the wall, water had penetrated the consumer units, wiring was burnt out, verdigree on terminals, old cloth covered tails soaking wet, IR readings of <1 Mohm, Consumer units rotted away (old wylex), exposed live parts, main fuse had blown (replaced by DNO), no lighting, difficult access (cellar with no stairs)...need I go on?
Up here the DNO (Scottish Power) would refuse to reconnect the supply without a certificate from an electrician saying the install was tested and OK.
I use these occasionally (2/3 in past year). I may use more than most as I do a lot of inspection and testing for 'skint' landlords.
It covers my back and places the liability on the client / landlord where there are exposed live parts.
Was at one on Friday to connect a cooker where the consumer unit had blanks missing - new tenants from down south who were unaware that the landlord had to install mains smoke detectors (not done) and provide a satisfactory electrical cert (also not done)
One landlord I issued a DN for ignored it completely. The consumer unit cover was broken and off.
A month later she got in touch to ask if I could go to a tripped breaker at the property. I went round, nothing had changed. I re-issued the DN and refused to do any work impressing that the tenants were in immediate danger. No response at all. Until a month later, when she asked if I could quote for 25+ led downlights in her ÂŁ900k house.
The best bit ? The tenant was her own son and his uni mates.
Reply to Issueing "danger notices" in the UK Electrical Forum area at ElectriciansForums.net
It looked like the live connection side ( internally) burned against the neutral of the main switch
They have done electrical work... they should test it before anyone else gets a chance to alter it. In fact... here it is from the BBB "641.1...
