IT Earthing | Page 2 | on ElectriciansForums
Discuss IT Earthing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I would hazard a guess that most TT systems at this time of year & in this kind of weather would now exceed acceptable values.
In some instances this could prove a bit of an issue under fault conditions....
is this not one of the reasons the regs. stipulate RCD protection on TT systems?.
Reply to IT Earthing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
All the lamp post cutouts I've ever seen have a twin swa gland plate built in to the base.
loz2754
L
