Ive broken the front cover to the consumer unit | Page 4 | on ElectriciansForums
Discuss Ive broken the front cover to the consumer unit in the UK Electrical Forum area at ElectriciansForums.net
L
lofts
HI guys
Ive accidently broken the consumer unit in the empty property im working in at the moment. I took the cover off of the Memra 2000 Ad board having isolated all the breakers, rcd's and main switch then I took the main fuse out (yes Ive taken the main fuse out before with out doing so and it was just a little bit scary with all the sparks and crackling noises)
Being a bit heavy handed and just rushing I guess Ive gone and broken the front cover so that it wont screw up tight at all.
I cant say that taping it on would be a good look, and I cant see that being acceptable at all. I also wouldnt want to do that but My dilema is this. I not sure the company has plans to do a board change even tho I have added a new kitchen ring to the old board board. additional sockets on both the up and down stairs RFS's etc. I have adivised that they have a board change to bring it up to current regs (17th eddition board) as I have made alterations and additions that need to comply with BS7671. Ive been told there going to look into it, but if it is allowed I guess they will just try and put the new kitchen ring on a rcbo and the existing up and downstairs rings both with additional sockets added to them on a rcbo as well as this will comply and allow them to keep costs down.
cheers
What can I do if they go for this option as I cant leave this cover like it is, its just waiting to fall of exposing all the live parts etc, also the earth bar inside this cosumer unit is a bit loose imo.
Jeez, I hope I don't end up living in one of these houses you guys are renovating. No offence. Just saying like. Daz
LOST!
[ElectriciansForums.net] Ive broken the front cover to the consumer unit
If found, please return to...
seeing as ive never filled before what filler is best for the job. I could probably try a few over time and draw myown conclusions but maybee you could save me the trouble and point me in the right direction.
ins not exactly a big hole its just 3 chases 2 chases going behing a duel patress box for the fused spur and tripple pole isolator and the other chase for the cable feeding the tranny. Ive already mounted the patress box and tranny and teminated all the connections to save some time. my concern is that where the patress box and transformer box sits there is about an inch maybee 2 of chase behing it. when the plastercomes and covers over these chases plaster is just going to fall down the back and presumably keep doing so as i took out the cut out to feed my cables through. whats going to happen is that my boxes are just going to get filled with plaster if im nopt carfeull so I just wondered hat a possible solution would be. Im thinking tape up the cut outs as best i can and then fill it with filler as best I can.
cwt?
Reply to Ive broken the front cover to the consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
