B
barrymilne
Hi all - first post...............
Just passed the 17th the other day, and want to confirm if my undersatnding is correct.
If I have a cable (1.5mm T&E) which was inadvertently cut and required joining, but I did not want to create an inspection hatch in the roof, and couldn't run a new cable is the following method acceptable.
CPC sleeved on both ends of cable, line and neutral prepared, all conductors joined with insulated crimps and places in a plastic 'choc box' (as seen on dragons den), both cables secured with cable clamps within enclosure. Box mounted on ceiling joists at least 50mm from face of plasterboard. Ceiling made good with no facilty to inspect the completed enclosure.
Think that covers it.
Cheers
Barry
Cheers
Barry
