I'll take a guess that the transformer on the original panel has popped its thermal fuse. These wiring centres often get placed in positions where the ambient temperature can reach 50C or so, and that, combined with the heat produced by the Tx in its normal operation, can take its temperature past the fuse's popping point.Think you need to establish why it has lost power as likely the replacement panel wont work either.
Didn't mean it had lost power due to it being discontinued! Meant old panel was better and new had different wiring etc. Can't work out y it's lost power as electrician had a look and fuses within panel ok. Also all wires have power.It wont have lost power because it is a discontinued panel and JG have brought out a replacement panel!
Layout slightly different but same terminals/connections by look of it!
Are you a electrician/ ufh specialist and local to Derby?It wont have lost power because it is a discontinued panel and JG have brought out a replacement panel!
Fuses all ok and All wires have power so whats the problem?fuses within panel ok. Also all wires have power.
The control box is normally always lit up monitoring the UFH however no lights on display and no UFH.Fuses all ok and All wires have power so whats the problem?
No both fuses test okI'll take a guess that the transformer on the original panel has popped its thermal fuse. These wiring centres often get placed in positions where the ambient temperature can reach 50C or so, and that, combined with the heat produced by the Tx in its normal operation, can take its temperature past the fuse's popping point.
It's a thermal fuse, built deep into the transformer, that I'm referring to, not the replaceable cartridge fuses on the panel.No both fuses test ok
Not changed to new board, reason i posted was if anyone had similar problem with JG Control panel going out.Can you post a photo of the connected new panel with all terminations clear in the photo
Is it possible to access the thermal fuse, I would rather try to fix any issue with current panel as too much messing around changing wires over to new board which I'm not to keen on. Anyone local in Derby would be good ţo check it outIt's a thermal fuse, built deep into the transformer, that I'm referring to, not the replaceable cartridge fuses on the panel.
Reply to the thread, titled "JG UFH wiring control box no power" which is posted in Electric Underfloor Heating Wiring on Electricians Forums.
