Joining a cable to be buried in a wall | on ElectriciansForums
Discuss Joining a cable to be buried in a wall in the UK Electrical Forum area at ElectriciansForums.net
SJD
Mentor
Braccan heal
Now and again, I need to join a cable that is buried in a wall, sometimes in a stud wall, sometimes to be plastered over. Sometimes when someone has drilled through it (last one was a kitchen fitter who should have known better), or sometimes to extend a cable e.g. to move an accessory lower on the wall. Generally I'm thinking of 2.5mm2 or 1/1.5mm2 twin & earth. And assuming a new cable can't easily be pulled through.
What jointing method do people prefer?
I've used heatshrink crimp butt connectors plus an outer covering of glue-lined heatshrink. I worry about the crimp not gripping one of the conductors tightly enough and it coming loose.
I've also used heatshrink solder connectors, again with an outer glue-line h/s covering. If the copper is not clean enough, I worry about a dry joint to one of the conductors.
And what if one cable is new solid T&E, while the other cable is stranded imperial cable?
Wagos
I've left a Wagobox in a stud wall a few times, but not always practical when there is not enough slack in the cables (the cables all enter one end in the standard Wagobox).
But actually, is there anything to stop me burying a Wagobox in a solid wall and plastering over? I've never thought of doing that.
Dunno mate, but that's a right rough old job imo
well if the cable is tight and not much slack available to join, then why not add a extra section in ... say 3 or 4 inches. you will then have 2 joins but at least you got the slack to do a good job of it.
In terms of tightness after crimping, give it a tug and if it comes loose, its no good. if all holds firm then move onto the heat shrink/wrap.
There is only so much you can do before you replace who sections of cable.
In a scenario of cable being drilled into for example, as a last resort the cable can't be replaced, joint can't be left above wall unit etc (Wago), I've used butt connectors & heat shrink, as you've suggested. I bought some of these, but not used them yet;
[ElectriciansForums.net] Joining a cable to be buried in a wall
They'll be some arguing against using crimp connectors on solid cables, but I've seen that disputed on another forum.
PS Lets not have any book shelf jokes :)
You could also sink in a small weatherproof box and use Wagos or similar within, really it would have to be within a safe zone though, not that anybody other than Sparks' know the slightest thing about them. :)
I always have a kit with through crimps, I then solder, then individual heat shrink, then complete heat shrink, staggering the joints to make it neat.
I find that I can walk away and not think of high resistant joints etc - plus I really enjoy the practical part of it.
I would consider adding a length if required or even adding in a chopped in box. Anything to get the job done right if a new cable is not possible.
Are these unsleeved crimps that you solder by heating and manually by feeding in solder, or are they some assembly with a solder ring, a bit like the photo posted by Midwest but with a crimp section as well?
Reply to Joining a cable to be buried in a wall in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
