Joining cables before plastering | Page 2 | on ElectriciansForums
Discuss Joining cables before plastering in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If it's not been plastered I'd be enclined to replace a length of cable din to the socket (presumably) and stick a wago box above the ceiling.
if not particularly practical, crimp and a few layers of heat shrink and tape should do it.
Agree, I normally use online idea maintenance free connections and Wago box and chisel the wall to bury it so it will be below the plaster.
...Don't tell me you buy it? Don't you lot have tallow and killed-acids to hand?
Real men silver solder,braze,or forge-weld using river sand as flux :pirate:
Reply to Joining cables before plastering in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
And if it's a garage then use metal clad accessories.
Sounds more positive.
