• Please use style selector to select BLUE AND WHITE. If you are not already on it. This notice will go once you're on the correct style.
Joining cables before plastering
If it's not been plastered I'd be enclined to replace a length of cable din to the socket (presumably) and stick a wago box above the ceiling.
if not particularly practical, crimp and a few layers of heat shrink and tape should do it.
Agree, I normally use online idea maintenance free connections and Wago box and chisel the wall to bury it so it will be below the plaster.
...Don't tell me you buy it? Don't you lot have tallow and killed-acids to hand?
Real men silver solder,braze,or forge-weld using river sand as flux :pirate:
