NICEIC Certification Scheme Joining NICEIC
Here you go E54, get checking the boxes
I had a look thought it and fell off the bottom following the NO’s.
I’ve never had time for or need for either the NIC-EIC or JIB and nothing will change my views on them.
Well that just shows how little you know then, you ''NEED'' the 17th cert to join any Scam provider!! Not that, that is worth much in the greater scheme of things!!
When I had my assessment I had to show originals of 2390 parts 1 & 2. NVQ3. (I had a NVQ2 also) and either a 2391 or spend half a day showing him I could test. That was BEFORE we done anything else.
That was the MINIMUM requirement i posted, exactly what all Scam assessments are based around, the lowest possible denominator!!
Yeah right, as if a Electrical Trainee would have any of those qualifications, but they all still get enrolled into these Scams. Or are you and others here talking about ''Approved Contractor'' assessments, which is not what the thread is about.
