Joint between 16mm &1.5mm! | Page 4 | on ElectriciansForums
Discuss Joint between 16mm &1.5mm! in the UK Electrical Forum area at ElectriciansForums.net
rolyberkin
Nearly Esteemed
Chelmsford
A donut of a builder has helpfully run a piece of swa two core 16mm to a small feature fountain fitted with 1.5mm flex, suggestions on best way to join, couldn’t get the 16mm in a wago!
Reply to Joint between 16mm &1.5mm! in the UK Electrical Forum area at ElectriciansForums.net
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
