Judging imperial submain T&E cable | Page 2 | on ElectriciansForums
Discuss Judging imperial submain T&E cable in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Rubber disappeared a bit earlier, you can get imperial PVC cables but no metric rubber as far as I know.
The give away is the conductors, tinned and stranded = imperial, solid with no tin = metric.
You also got Imperial PVC twin with no earth.
Reply to Judging imperial submain T&E cable in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
Thanks for your time and opinion.
