just been zapped from my kitchen sink why did it happen | Page 8 | on ElectriciansForums
Discuss just been zapped from my kitchen sink why did it happen in the UK Electrical Forum area at ElectriciansForums.net
J
jayjay5396
hi i would like to know why i just received an electric shock from my kitchen sink all i did was touch the tap to turn it on i got hit n it hurt why would this happen?
ive used the tap before i've lived here for 7 years whats up with it why did i get a shock?
would an electrian cost alot of money to fix it?
Had a similar problem a long while ago. The customer had had a light fitting replaced on the landing and wired with the neutral and earth swapped over.
The property had no rcd protection and had rewire able fuses.
They had a new kitchen fitted and the fitter removed the water bon which was the electrical systems only means of earth.
From then on whenever they turned the light on on the landing it made most of the properties metal work live.
DIY - you pay the price in the end !
Reply to just been zapped from my kitchen sink why did it happen in the UK Electrical Forum area at ElectriciansForums.net
The sink is probably not an extraneous conductive part and probably does not require bonding to the met ,your electrician should have done an ir...
DHW supply from Vaillant turbomax 828e Hi, We have a combi boiler supplying dhw and c/h to our 4 bed, 2 bath house. The boiler is in a cupboard...
diddlepara
