OP
Engineer54
I would never suggest that you cut off any plug tops off any appliance, as this would in validate any warranty on that appliance.
Sav
How many more times!!!! NO IT Doesn't!!!
Discuss Kitchen appliances in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Sav
Just to clarify, where do we stand on this. A guy I work with is adamant that it invalidates the warranty. If I tell him it doesn't I'm going to need more than "a guy off the Internet told me"
This point has already been covered in other threads and NO!!!!! it dosn't invalidate the warranty, if changed or fitted to fcu by a competent person, in the event of a fault on the appliance a cover note from the electrician that it was done by himself and tested will normally do, some firms out there though will try it on and you need to get an independant technician to confirm the item hadn't gone faulty due to an incorrectly fitted plug or flex termination.I would never suggest that you cut off any plug tops off any appliance, as this would in validate any warranty on that appliance.
Sav
Ive had a computer and stereo system replaced 2yrs after the 12month warranty ran out because i know how to use the system and i will never waste my money on extended warranty options as you already legally are covered but hey! thats a totally different thread altogether.
Without going too indepth the consumers rights act 1979 has a clause stressing that any goods bought should give a reasonable service life, so if your warranty is one yr and on yr 3 your washer timer board goes faulty then firstly you get an independent engineer report expressing the part that is faulty is due to part alone malfuctioning before its expected lifespan and it also need to show that its not because of consumer mis-use or damage. After they accept this report they will then take the appliance etc for their own team to fault and if you are honest it should show the same verdict, part or product then replaced and sometimes all your cost of independant engineer too.Sounds like an interesting read......
They should be readily accessible.
So yeh in a cupboard isn't a issue if there not buried away at the back.
You could just put sockets in the cupboards in accessible places. Then no need for isolation switches.
Switches should be inside cabinets because of kids. :90: I've the same wiring in my kitchen.
This is the best idea, you can use it. It costs less!!
Reply to Kitchen appliances in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
