Kitchen - full rewire | Page 2 | on ElectriciansForums
Discuss Kitchen - full rewire in the UK Electrical Forum area at ElectriciansForums.net
London
Greetings everyone
We are rewiring a house and have reached the kitchen.
We have run a 2.5mm cable from consumer unit which will connect as ring for over worktop sockets, and in the same ring we plan to run spurs (switched and fused) for:
1. washing machine
2. dishwasher
3. boiler
4. gas hob spark
5. extractor hood
6. cooker (not on the same ring, but on separate 6mm cable run from consumer unit)
Since the kitchen is empty (no installed units wall units/cabinets) we have plenty of space and want to make a tidy job.
My questions are:
1. Is it OK to have spurs for all listed items above i.e. should we remove anything and have it straight on the ring?
2. We plan to install all switches in one place under worktop (no cabinet will be installed here, access will be very easy) instead of having switches near appliances. Should we chase and dig the switches into the walls, or have them surface mounted. (what is legal requirement)
3. Switches would be about 2.5 meters from all appliances, but very easily accessed. Is this ok?
4. Any suggestions would be highly appreciated
Many thanks in advance!
Because WE don't have a clue, we were just issued a new install certificate by electrician with a comment of a "good and tidy" job.
There is nothing worse than arrogance.
i don't understand. your OP says you have run cables and asks for advice. now you say a spark has issued an installation certificate. the two are not compatible or sensible.
it's a bit like saying you have a medical problem with your elephant, what do i do?
then saying vet has treated him and he's OK
Glad you got it all sorted mate.
If you knew an electrician was going to do a cert for this work then how come you just didn't ask him/her the questions? After all they are putting their name to the work..
You'll get a better response if you post a copy of the cert you refer to (names and addresses deleted). Otherwise nobody will believe you are doing this correctly and in accordance with Part P, which is a legal requirement.
Has this been supervised and staged checked by an electrician in a third party scheme if so which one? It is correct what has been said previously the electrician is supposed to of signed your design off before you start so why are the questions being asked?
OP, post a copy of the certificate as requested. People will be able to get a better idea of what's going on.
Me neither. Worth a try though eh.
I didn't really see the point in the post, if they had an electrician coming to sign it off...
It's always good how we find out the full story at the end of the posts...:)
Reply to Kitchen - full rewire in the UK Electrical Forum area at ElectriciansForums.net
It's not the same scenario, though. Tails more than 3mtrs can be overcome by using a fused switch and rcd board, whether the earthing system is...
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
