Kitchen wiring - please tell me if I'm wrong.... | Page 3 | on ElectriciansForums
Discuss Kitchen wiring - please tell me if I'm wrong.... in the UK Electrical Forum area at ElectriciansForums.net
M
martom
Hi, I need your advice again
I have a flat to do: Old CU, old wires colour, kitchen radial 4mm
To do - rewire kitchen, new CU
I checked the installation, will not trip the RCD ;)
Now the question - I would like for my peace of mind run new cable from CU for the kitchen circuit, but the kitchen is ca 15m away from CU, newly redecorated corridor, lounge ets.
Q1) Is it OK to crimp new 4mm to the old one and just rewire the kitchen?
Q2) One of the bedroom sockets is powered by a kitchen circuit. Is it al-right by regulation?
Tom
Yes I am registered with part p scheme already. That's a strange thing for me as well. I am used to a situation that my qualifications are enough to do the job. No need to pay every year for proving something what was proved at school. Does GP need to be checked every year for his competence? does he pays for it??
Hi martom
As darkwood has said, the crimp will need to be spot on as it will carry a considerable current, potentially.
I understand what you are trying to achieve but am worried about that joint! Can you not use an enclosure to be sure and a maintained joint?
I will say what many will think, again please do not take the wrong way as I also know nothing about you or your past, training, etc.
It's just that your question is so basic (extending a cable). That was all.
Btw the thing with the bedroom socket - in my opinion mixing up sockets across rooms & circuits is the best design!
Thanks for your support, i found a different solution for this. As there was a no used anymore 4 mm radial (old immersion heater which has been exchanged to combination boiler) finally i created 4mm ring circuit for kitchen, protected by 32A breaker. Connections has been made in a accessible enclosure in a cupboard near to the kitchen. No hidden joints, no worries about installation method.
I know that my question about cable connection was a basic one, but i didn't ask how to do it. I was only confused about one circuit - two wires colours by the regs.
Thanks for help;
all the best
Tom
Thanks for help;
all the best
Tom
Youve made a 4mm ring from an old 4mm radial???????
Being checked annually for Part P isn't just about your qualifications, its about your insurance, your test equipment and calibration, the certificates you do, having jobs inspected by your scheme, checking you have the correct and up to date regs books..... and this is planned to be introduced for doctors
Reply to Kitchen wiring - please tell me if I'm wrong.... in the UK Electrical Forum area at ElectriciansForums.net
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
