As per the title.
Discuss L,A,B,Cs how do these bodies quantify someone as a Competent Person in the UK Electrical Forum area at ElectriciansForums.net
Thought it might pique a few members curiosity.Now that IS an interesting question .............
What are you infering Dillb?
I registered once for ELECSA, on my “assessment” I had to carry out a RCD test on a socket. My tester has the auto function on it, it took me 2 minutes. I was then told that’s enough and I am now deemed “competent”. Make of that what you will.What are you infering Dillb?
Figures, did it cost you anything? So is it another tick in the box, by people who know diddly squat about Electrics, know relection on you whatsoever Dillb, just theorising as you do.I registered once for ELECSA, on my “assessment” I had to carry out a RCD test on a socket. My tester has the auto function on it, it took me 2 minutes. I was then told that’s enough and I am now deemed “competent”. Make of that what you will.
Well you got to do what you got do to survive cant say I agree from what has been going on this afternoon.Yes about £400 plus half a day off work.
Thanks but the issue I'm referring to the subject does not belong to a part P CPS, does the phrase left hand doesn't know what the right hand is up to? a bit like Government compartmentalisation springs to mind, and I should know.When I started up I called my 2 local LABC offices and asked what they needed to deem me competent and notify work directly with them.
"Erm, never been asked that, so we're not set up for it. Just join a scheme" Was the answer both times.
Reply to L,A,B,Cs how do these bodies quantify someone as a Competent Person in the UK Electrical Forum area at ElectriciansForums.net
