L,A,B,Cs how do these bodies quantify someone as a Competent Person | on ElectriciansForums
Discuss L,A,B,Cs how do these bodies quantify someone as a Competent Person in the UK Electrical Forum area at ElectriciansForums.net
What are you infering Dillb?
I registered once for ELECSA, on my “assessment” I had to carry out a RCD test on a socket. My tester has the auto function on it, it took me 2 minutes. I was then told that’s enough and I am now deemed “competent”. Make of that what you will.
Figures, did it cost you anything? So is it another tick in the box, by people who know diddly squat about Electrics, know relection on you whatsoever Dillb, just theorising as you do.
In defence my Elecsa assessor was really good. Made me carry out a full range of tests on initial assessment and did a thorough job every year.
When I started up I called my 2 local LABC offices and asked what they needed to deem me competent and notify work directly with them.
"Erm, never been asked that, so we're not set up for it. Just join a scheme" Was the answer both times.
Hi Pete,
When I rewired my house I enquired with Stoke LBC as they had the two tier charging system (i, qualified but not part of a scheme, and ii, non-qualified) and buried in the small print of their Building Control Guidance was a note that the qualification required was the C&G 2392 -Level 2 Certificate in fundamental Inspection, Testing and Initial Verification.
Thanks but the issue I'm referring to the subject does not belong to a part P CPS, does the phrase left hand doesn't know what the right hand is up to? a bit like Government compartmentalisation springs to mind, and I should know.
Reply to L,A,B,Cs how do these bodies quantify someone as a Competent Person in the UK Electrical Forum area at ElectriciansForums.net
NICEIC Certification Scheme NICEIC Competant person scheme
This sounds very similar to me. My level 3 NVQ is in engineering maintenance and I also have a HNC in Operations Engineering. I’ve been working...
ESP - https://www.espuk.com/# is the company you are referring to part of Scolmore
