View the thread, titled "L & N at the switch" which is posted in Electrical Wiring, Theories and Regulations on Electricians Forums.
wrong, wago's are not mf unless there in there enclosure e.g. cable restraints used etc
so would need fixing
more old wives cobblers. wagos must be enclosed, i agree. what is the back box if it's not an enclosure?
Shanks has come out with a few dodgy comments over the last few months.
Is someone at his work pulling his chain?!?! :smilielol5:
I'm in danger of sounding like a pedantic old bugger here but..
The enclosure would have to be marked with the BS number etc to be considered an MF enclosure, hence the daft MF ties for the line enclosures.
And if its in a back box it doesn't need to be MF anyway.
The connections on the accessory are screw terminals and no extra cable restraint is required.
Pedantry over. :)
so would need fixing.
There is no requirement to secure the terminal blocks providing the cables are glanded or secured outside the enclosure using a gland or clips etc.
This chestnut goes back a long way and dies hard with some...E54 being a prime case! When I started 35 years ago it was frowned upon and was actually forbidden on local authority contracts. some time in the eighties thinking began to change as nobody could come up with a valid reason as to why it was bad practice.
The bad practice brigade always state that there is no point in having a neutral at a switch as it is not required. This ignores the fact that a 3 plate lighting scheme will have a permanant live at each light...which isnt required!
They also state that neutrals at a switch will make for an unecessarily congested enclosure....this ignores the fact that a 3 plate lighting scheme will make for an unecessarily congested light!
The sensible approach is to install a circuit which best suits the requirements and install enclosures adequate for the wiring being installed.
Hi just reply to my earlier post about the wago's & the connectors this straight from the horses sorry Scam providers, last visit checked out a switch for that exact reason
Reply to the thread, titled "L & N at the switch" which is posted in Electrical Wiring, Theories and Regulations on Electricians Forums.
