Landlord consumer unit | Page 2 | on ElectriciansForums
Discuss Landlord consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Weston
Stoke
I have just had a rental property tested. The electrician says my consumer unit needs replacing as it is not split load.i am only using 5ways of the current consumer unit and all cct,s are rcd protected. Is this correct?
Ask for, and publish on here, the regulation numbers that it contravenes,he should have supplied you with the information in the report
Post a picture of the existing and we can go from there
In fairness there is no requirement to record the Regulation numbers against the observations in the Report.
I am the landlord. I have an electrical background but not domestic so am unsure of the current regs. The installation is as Anthonybragg describes. All other parts of the installation have passed other than the split load issue. Seems a little over the top for five cct terraced house!
I did not say there was a requirement :(
If he has a schedule of inspections he should be able to note the number of the particular regulation where a non conformity occured against the coding given for any problems
It would indicate why the inspector feels it does not comply
What code is placed against this issue ? As said above, any competent inspector would have noted this as a C3 at most.
The term split load is also incorrect.
I beg to differ.How is it incorrect?
Screwfix sell MK SPLIT LOAD boards here?
Split load generally referred to part non rcd and part rcd. Your pic is generally referred to as dual rcd. The OPs board has five circuits so I suspect his terminology is at odds with what he means.
No cert has been issued yet. Just told over the phone. Was going to do the work myself then he’d retest and issue the cert. wanted to make sure the work was necessary because of time and cost
Split load refers to having two separately controlled supplies(either rcd or non rcd protected) fed via one main switch.If the OP had a split load board fitted then 2 circuits would be on one rcd and 3 circuits on the other.(Quite often i find that when separating the circuits in a 5 way board that there is usually a extra circuit that has been popped into say a 32 amp breaker with the ring.When fitting the new board,this extra circuit can go on its own 16 amp breaker and you'll end up with 3 circuits on one side and 3 on the other)
The chances are,if a new consumer unit be fitted it will likely be a metal clad number with two Rcds to split the circuits
In my own opinion the system you have currently is safer than whats presently permitted for TT systems
That is because the casing has the potential to become live with no protection by disconnection required
By that I mean no protection other than what they seem to term "enhanced protection" a sort of clamping or support to the tails to prevent the possible nasty fault occurring where a live exposed tails can touch the metal,perhaps just relying on only the supply fuse to hopefully pop
There again you could fit a Rcd before the tails to better protect,but don't you already have that?:)
Reply to Landlord consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Google says that North Walney is in the Lake District? Have we moved the wall :)
2 3
