Landlords electrical safety certificate | on ElectriciansForums
Discuss Landlords electrical safety certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
P
PMS
Can anyone tell me exactly what is a landlords electrical safety certificate, is it just a pir on the fixed wiring or pat testing on all the appliances or both. is there a certain type of certificate dedicated for this.Have you got to be a member of a scheme provider such as napit or niceic. who would ask a landlord to supply this. your help would be appreciated.
There is no such thing as an electrical land lords safety certificate thats somthing drawn up by letting agents its a periodic inspection report ...which is a test of the electrical installation and could include pat testing if its requested by the land lord , i had a peridic refused by a letting agent because they wanted a landlords safty certificate ,but i did explain there is no such thing , but there are people issuing them and be honest some are not worth the paper they are written on
yes learnt about pirs when i done my level 3, but didnt hear the term landlords electrical certificate
thats because there isnt one as i have said its a Periodic inspection certificate soon to be changed when the amendments to the regs comes out in june
when i say pir i mean "periodic inspection report" which i thought was the name of the report as your issuing a report not a certificate on the installation
Correct its a periodic inspection repoert , not a landlords safety certificate as there is no such thing
Nickblake got suckered into the certificate frame of mind by persistent questioning of the issue by the defence :)
If they ask for a Landlord safety certificate,its not worth trying to educate them.just issue the periodic certif I mean, report
Bear in mind they also accept bog rolls as safety certificates :mad:
Yes des im a sucker lol but it annoys me when i get periodics refused and they say the can only accept land lords certificates ,yep your right when you say the bog roll , its true , one guy has issued a bog roll land lord cert , unfortunatly i went in a month later to a blowing fuse and issued my own cert .. a danger notification ...
Not a week goes by without someone asking for "an NIC certificate" or "a landlords certificate" I've given up on educating them, I just go along with it and carry out a PIR.
The infuriating bit is where they've had a Visual Condition Report done previously for a ridiculous sum (some below ÂŁ50.00).
Then I try to educate them with the ESC leaflet on Landlords Duties: http://www.esc.org.uk/pdfs/business-and-community/guidance-for/ESClandlordsGuide.pdf
I'm ashamed to say that my own scheme provider (NICEIC) promote these Visual Condition Reports which in a miniscule amount of cases are used as per guidance but more usually, just to con the ignorant client into some low cost, worthless piece of paper!
im so suprised that the NIC do visual certs as some seriouse faults can be found when doing testing and i agree with what you have said the esc link is great i have a land lord whos a star and listens to what i say and i printed off the land lords guide and gave it to her , just so frustrating
Is there a particular form for this from any organisation or is it just something you write yourself?
Napit have the same thing
They both have a box for the customer to sign
The customer will probably tell us where to stick it, if we asked them to sign
Reply to Landlords electrical safety certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
Thanks mate for the advice, this is just what I was looking for. I think I’ll have to put some thought into the domestic route due to the NVQ and...
