Laser measures
Amp David
Mentor
Does anyone use them and are they any good?
Had a stanley one years ago, but was rubbish. Not consistant at all, it was an ultrasonic version. Are the ones that use the laser to measure any better. I read that they have a tolerence of +/- 1.5mm. Is this right?
We use PLS and de walt both very good and robust, PLS has multi functions for setting out etc.
If they are saying an accuracy of+/- 1.5mm then i reckon they can be used rather accurately, or is it just the manufacturer blag?
Leica Disto every time, used by surveyors and architects. Very accurate easy to use and reliable i have been using them for years. Only one for me.
Leica Disto are excellent. But i doubt any better than the Bosch at the end of the day . Like for like i think they would give same reseluts
Fluke do a complete range
The top unit is accurate to +/-1.5mm at 100mtrs.
It also works out volumes, and heights using pythagoras calculations.
I don't know how the prices stack up but i have seen it on some test equipment web sites.
Amp David,
Amp David,
TrueNAS JBOD Storage Server
