lathe and plaster and downlights!!! | Page 3 | on ElectriciansForums
Discuss lathe and plaster and downlights!!! in the UK Electrical Forum area at ElectriciansForums.net
J.C.E
Earth
Any tips on cutting 76mm holes (20+) for LED downlights in L+P ceilings??
brand new 76mm yellow starrett cutter and 36v drill.....barely scratched the surface on ONE hole and the teeth are already near blunt!
cheers guys
Starrett recommended to me their carbide tipped holesaw, since the lathe and plaster is very abrasive. It works well, a bit more money than the standard but worth the investment is you are doing 20+. Worth pointing out to customer you won't be responsible for extra damage if the ceiling decides to come down at the same time. You would then probably have to wait a few months to get a competent lime plasterer in to make repairs. Trust it is a sound L+P ceiling before you started? i.e. no bulges or sagging indicating that the lathe and plaster have parted company.
Maybe it's just me set in me ways old fashioned and the like, I would not entertain cutting in down lights in L&P. The ceiling is not designed for such activity. IMO
I agree, they definitely are not! but when you got a regular customer hell bent on it......As some guys have said, don't attempt on a flaky ceiling, and tell them in writing you are not responsible if it all comes south. Most of the lofts above are kin awful as well.
Reply to lathe and plaster and downlights!!! in the UK Electrical Forum area at ElectriciansForums.net
