leakage | on ElectriciansForums
Discuss leakage in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
Northern Ireland
got a call on Saturday to say the newish washing machine is blowing the trip. when i had nosey around swapping leads and whatever i tried still tripping when starts a cycle.
its a tt installation with a ze of 14 ohms , insulation resistance of machine was as follows
l-e 1.3 M/ohms
n-e 12 M/ohms
earth continuity from plug to metal part of machine was 1.6 ohms
what i thought was an rcd is actual a voltage measuring device, apparently were installed before rcd came about , had no rating on it but has a yellow test button.
what else can i try or if i ring an appliance engineer what will he tell me. or what will he do.
thanks if your full of knowhow. im all ear or eyes
only get as far as page 3 all time..
.. need to clamp meter to measure earth leakage then can change device accordingly ..with a ze of 14 ohm i can get away 100mA - 500mA
would these devices be more sensitive than rcds?? id say no. but can somone explain how they work
you should be installing a 30mA RCD anyway. but, yes, by all means check installation leakage or global IR test before fitting RCD or you might end up spending an extra day sorting out problems which you haven't allowed for in your quote.
Well if there is a Voltage trip chances the fuseboard isn't 17th compliant?
If I were you I would be giving the customer two choices - direct replacement with 30ma rcd (not recommended)
Fuse board upgrade.
then fix any problems like washing machines.
Voltage trips operate when the touch voltage rises above 50V (unless I'm mistaken)
but are unreliable due to parallel paths making them inoperative.
I havent measured the earth leakage yet.
If i know how these voltage devices operate then i can start from the start of working out what is going on.. Dont forget im a newbie so never seen one of the devices before or worked with them
irrelevant how or if they work-- it wants ripping out . end of. i wouldn't expect my motor mechanic to know how steam engines worked ( that's one for engineer54, he'll know. LOL.)
Reply to leakage in the UK Electrical Forum area at ElectriciansForums.net
Just an update for anyone interested, I got another rod in outside today, which has lowered the Zs db to a more healthy 53ohms. The oven elements...
2 3
