LED Dimmer Knob | on ElectriciansForums
Discuss LED Dimmer Knob in the Lighting Forum area at ElectriciansForums.net
Washington
HI all, first post so "hello" I guess.
I am working on a desk lamp that uses a standard E26 socket, and uses a rotary dimmer switch to control the brightness and on/off of the bulb.
I have two questions:
1. Both of the LED rotary dimmers I bought on amazon only control the bulb brightness in the top 25% of the rotary motion. In other words, from the off position, you have to turn it about 75% of the way until the bulb turns on. I am using a 'dimmable' LED bulb. Any thoughts? just a bad dimmer? Or is there a different type I should use? Do I need an LED driver?
2. If I am using an LED bulb, what size wire can I run through the stem to the bulb? Do I need 16 ga. lamp wire or can I downsize because of the low volts of the bulb?
Any info appreciated! Cheers,
Reply to LED Dimmer Knob in the Lighting Forum area at ElectriciansForums.net
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
try a varilight pro dimmer for led's
