LED don’t work | Page 2 | on ElectriciansForums
Discuss LED don’t work in the Lighting Forum area at ElectriciansForums.net
Agree with above.
Presently you have 2 hotspots. The lamp and the transformer. Neither like insulation above them, and you’ll find the plasterboard around the holes quite brittle.
Easiest method is the all-in-ones. Quicker to fit and most are the same hole size as the older downlights.
Basically, transformers give out AC current, and drivers are DC, specifically for LED circuits.
Reply to LED don’t work in the Lighting Forum area at ElectriciansForums.net
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
Hi all I've been changing the halogen downlighters in my house to LED's. I have three rooms that use dimmers, two of them have two switches each...
