LED Driver | Page 2 | on ElectriciansForums
Discuss LED Driver in the UK Electrical Forum area at ElectriciansForums.net
I have recently bought a reel of SMD LED strip lighting. I know it's suggested that you use an LED driver to power these but they seem very expensive. I was wandering if I could use a standard electronic transformer used for powering LV spotlights, as long as I meet the minimum load?
I struggle to see why not but am open to correction.
thanks. neil
I supply and install alot of LED Strip lighting. I find caged power supplies up to 150W 12V DC drive LED very well but if you group a few together on a circuit they sometimes cause RCD's to trip probably through leakage. There are some decent 60W LED drivers online from UK suppliers around the ÂŁ13 mark which look like slightly larger transformers. As already mentioned they need a constant power supply, I haven't seen any standard transformers drive LED without causing flickering or some other problem.
Most strip is supplied now at 12V DC allthough some do still get 24V DC strip but I have yet to use that to see what benefits it has over 12V DC.
Reply to LED Driver in the UK Electrical Forum area at ElectriciansForums.net
Hello. This is such a noob question, but I'm struggling with something that seems like it should be fairly straightforward. I have numerous 24v...
Thanks, No, I didn't use thermal paste, but I didn't run the LED at full voltage, I used a controller and it wasn't running hot . I used an LED...
