LED Lamps and extractor fan problems.. | Page 4 | on ElectriciansForums
Guest viewing is limited
Discuss LED Lamps and extractor fan problems.. in the UK Electrical Forum area at ElectriciansForums.net
A
ash_s3
A friend of mine has just replaced some halogen GU10 lamps in his bathroom with LED lamps from Amazon.
Hes saying since swapping the lamps, the extractor fan runs continuously. (230v in-line unit in the loft with over run timer)
He tried swapping one LED lamp back to halogen and it worked as it should, timing out after 5mins or so.
Removed the halogen (with the lights switched off) and the fan fired up by itself!
Anyone come across this before? Sounds like a resistance issue to me, would a resistor sort this out?
Cheers
I'm using the term in its general sense, "Bring about or give rise to". What's the concise term for "to cause a current to flow due to capacitive coupling"?
When discussing electricity the word induce has a specific meaning, using it otherwise is only going to give rise to confusion.
I doubt there is a concise term, we are talking about a technical/scientific subject which is something that doesn't work well with shortening terms down for convenience
I think in these cases, it's just a case of the circuit acting as a capacitor connected across an AC voltage source.
So it's just the 'natural' (high end terminology there!!!) current flow, in these cases in the order of micro Amps.
Which are starting to have a/or producing, odd effects on newer low power gear.
This may, or maynot be helpful but....
Today I investigated a bathroom where the lights (LED's) stayed on when the lights were off!
So I removed the cover of the ceiling mounted fan...... and narrowly avoided being "drenched" by the build up of water (condensation) that had accumulated and clearly the moisture was providing the "connection" between the SL and L.
With the fan cover off, and the fan disconnected, the lights now work perfectly.
Hope this is of use to some of you! [ElectriciansForums.net] LED Lamps and extractor fan problems..
Just wash away all our clever theories then! :)
I was just searching for a resolution to a similar problem. Changed some filament lamps in a Bathroom yesterday to LED. Customer messaged this morning to say the fan has been running all night and keeping her awake.
I am going back today to fit a "snubber" across the feed and switch line. Same as you would use when the led lights keep flashing. If you need one Google Danlers snubber.
I will post if it works, hope this helps, Cheers C.
This thread is nearly 8 years old I hope he has fixed it by now
Reply to LED Lamps and extractor fan problems.. in the UK Electrical Forum area at ElectriciansForums.net
Thanks for your advice guys. very helpful
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
Recommended Sponsor News
Hi everyone,
