Fitted my parents a little 10w LED PIR light over the front door to help them see the steps.
took a fuse spur from a ring socket with a 3A fuse. 2.5 T+E from socket to switch, 1.5 T+E from switch to JB.
it worked fine for about 5 mins then turned off. I thought it was the settings so played around with it but nothing.
I checked for voltage in the JB that is just above the light. No voltage.
Voltage is fine going into the switch but not going out the switch so it had to be the fuse.
Changed fuse for another 3A which blew instantly. Changed then to a 5A and blew again but light did light up for a second.
This struck me as odd because 3A should be more than enough. Anyway I changed it to 13A and now there is defo voltage from the switch to the light as Iv checked the JB which is fine so now looks like the light itself has had it.
what could be causing this? Iv checked all connections with my voltage tester and doesn't seem to be any L-N short.
Am am I missing something?
