N
NeilF
the only problem with these all-in-one fittings, is that you can't change the lamps (bulbs) if you want a change or don't like the particular light. personally i prefer SMDs as they have a wider spread.
Well, with the LEDLite ones you can change teh lens covers to change the beam ranging from 25 degrees to 90 degrees. This seems a good idea surely?
The only thing that concerns me about them is how they don't seem as common as Aurora? But they seem exactly the same animal, just brighter, and have the beam changing option!?
