Hi. I would like some advice on an LED fish tank light that I am trying to make. I am not sure if to use the CREE style 3w SMD's mounted on a 20mm star PCB or the larger square 10w LED's, I will decide later. But either way I need help working out the PSU if anyone would kindly steer me right.
The LED details are as follows.
10w, 0-12v, 1400mA.
Or
2.3w (CREE), forward voltage 3.3v, 700mA.
What kind of power supply would I need? Is it as simple as just one that is rated at 5x the voltage, current and wattage above? Or something else?
i have seen this driver with the following spec:
Model:LA50P-700
Input: 100-240Vac
Output: 36-72Vdc 700mA
Rated Loading: 11---20LED
Efficiency (at full load): >87%
Dimensions (LxWxH): 148x40x30mm
http://m.ebay.co.uk/itm/131346072951?cmd=VIDESC
Would I be right in thinking that this driver could be plugged into the wall at 240v (uk mains) and then run out to the LEDs in series. For example say 20x 3.3v, 700a, 2.3w LEDs as this should total 66volts.
In essence, am I also right in thinking that the current of the LEDs must match the driver, if it's less then a resistor must go in (for if I say have 6 blue at 700mA and 6 white at 900mA) and the total voltage of all LEDs added together may be within the drivers operating range?
if that bits right, I'm also thinking, if I have 900 and 700mA LEDs, get a 900 driver, run to the 900 leds first, then add a resister before going on to the 700 ones? Resister being V/I=R (2.3v/0.2A=3 ohm resister to bring it down 200mA to 700? Or is it the calculation of total voltage pulled/current? 66v/0.2A=330 ohm. Or then again, is it 66v/0.7A=94 ohm?
Oh it all gets very confusing.
I look forward to your responses.
Thanks, Steve.
10w, 0-12v, 1400mA.
Or
Model:LA50P-700
Input: 100-240Vac
Thanks, Steve.
