LED Transformer - No Instructions Supplied | on ElectriciansForums
Discuss LED Transformer - No Instructions Supplied in the Lighting Forum area at ElectriciansForums.net
I purchased a 100w LED Transformer (240v - 12v) from LED Hut. It came with no instructions. I contacted customer services and asked if I should switch at the input or output side of the transformer. The transformer has 2 outputs. I also asked LED Hut if each output was limited to 50w or if only one of the outputs were to be used could that be used up to a max of 100w. Their response was that they could not answer the question because they were not trained electricians and that I should consult a professional. I used to be a domestic installer but I career changed so I guess I can no longer class myself as professional. So my question to the professionals is: "is there any regulation that states that accessories such as this should be fitted iaw the manufacturers instructions"? Also is there any regulation that obliges the supplier to provide instructions? And lastly if there is a professional out there that can advise on my 2 technical questions regarding switching and outputs that would be greatly appreciated.
Generally switching would be performed on the 230Vac side to prevent permanently powering the power supply even though it should take minimal current when not connected to a load.
Generally a multi output driver can only output the maximum load divided equally between outputs, though there are exceptions.
There is no requirement I am aware of to supply instructions, or to install to the manufacturers instructions. Generally having both would be likely to be most successful; it is certainly possible that some non electrical regulation may require this.
The driver does not seem to specify on it, it is probably a generically printed label with only certain elements modified.
[ElectriciansForums.net] LED Transformer - No Instructions Supplied
1 -[if I should switch at the input or output side of thetransformer.] The switch should go on the input side of the transformer always.
2 - [The transformer has 2 outputs. I also asked LED Hut if each output was limited to 50w or if only one of the outputs were to be used could that be used up to a max of 100w].
Most likely you can put all 100w on any one set of terminals.
You do not have to put one on each.
Just make sure the cable can safely handle the load.
This is one of the many reasons I wouldn't use the likes of LED Hut. Not only do I not like the quality of what they are generally selling, but they don't seem to have a blooming clue as to what they are selling either.
If the resistance between the output positives and between the output negatives is near enough zero ohms (less than 0.1 ohms?) then the two outputs are probably connected to the same output internally. I would use both output cables paralleled up to share the current.
Reply to LED Transformer - No Instructions Supplied in the Lighting Forum area at ElectriciansForums.net
Interesting. Sounds unusual since it seems it was very lightly loaded. Not much you can do I suppose other than buy a replacement unit. Unless...
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
