daver
Completed a job about a month ago on a small extension. They created a downstairs toilet and shower which is L shaped. On the architects plans it showed a 700sq shower tray and enclosure.
So to describe it, you open the door and I have put light switch just inside. 3M and it turns and 3m further is the shower cubicle. So we are well out of the zones. No problem as I thought
What happened after I completed, was they changed the shower tray and decided to tile the floor and make it a wet room.
Its on its own RCD protected circuit and the switch, although within the room is some 6m from the shower.
Do I need to change this switch as this room has now changed to a wet room or are the zones still applicable. Just with the last line of reg below about conditions likely to be encountered.
Your help would be appreciated.
Regards
Dave
The general requirements in Parts 1 to 6 of the Regulations are applicable
outside of the zones including Regulation 512.2.1, which requires equipment to
be of a design appropriate to the situation in which it is to be used or its mode
of installation must take account of the conditions likely to be encountered.
Regards
Dave
