Light Switch in Wet Room | Page 2 | on ElectriciansForums
Discuss Light Switch in Wet Room in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Assuming that the room is fully RCD protected, then you will be safe.
Taking your example further, the drain becomes blocked, the water leaks under the door and as you walk out of the wet room in bare feet over the wet carpet, you switch on the hall light and....
Follow the regs and employ a little common sense on top. Only the person who sees the situation can really make the decision ultimately. That's why we are qualified professionals :)
Yes, I see the point. One could also apply it to the case with a "bath overflowing". I would always view a wet room as an extended shower area.
What "gets me" is the citing of distances from the edge of the shower tray and concluding that it's OK; as it's "far enough away". The point I was trying to make (maybe somewhat poorly :() is that the danger doesn't stop after a certain distance in an environment like this. The regs should always be considered as a minimum and you take into account the reason for a regulation existing when making decisions. In my view that's the "common sense on top" aspect in this situation.
Here you go, no neutral required and I'm sure they are rated at IP44, good bit of kit used these before with no problems :
WAPIR (PIR occupancy switches) - DANLERS Limited - Lighting Controls HVAC Controls
Just another option and presuming the wall is 100mm thickness or less, any chance you could drill through and mount a standard light switch on the opposite side outside the wet room ? Then blank off the existing point, either with a 'nice' blank plate or get them to bring the tiler back to tile over properly.
All the best,
Sy
I've just had a refresh on the regs for this. The definition of zones 0 & 1 horizontal reach for "showers without a basin" (which is effectively what this is) is extended to 1.2M from the centre point of the fixed water outlet on the wall or ceiling. Not sure what happens if it's a flexible head.
So I capitulate that this would be within the regs, I still think it's poor though; as the basin extends well beyond the 1.2M IMHO.
Wet rooms are common practice, and far more normal to see, than the standard British bath/shower room in Europe and indeed overseas as a whole. You won't find many of those with pull cords or occupation detectors, ...nope they tend to have the switch in the normal position, and these rooms can be a lot smaller than the room mentioned above.
Come on, ...6m away from the shower head, and around a corner, forget all the what if's it's Fine!!! lol!!
If I was designing it from scratch as a wet room I wouldn't design it with a plate switch within arms reach of the wet area, that's for sure ;)
Reply to Light Switch in Wet Room in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
I am confronted by people with experience in using them for lighting circuits and sockets in a three-phase installation, as it is only allowed to...
